Using a powersupply from Australia in England ok?
14 Oct 2009
UK
Basically I'm building a new pc and to save money I have dug up my thermaltake tr2 550w which I bought when I lived in australia and brought back....now will this be fine to use or do I need a new one??
a quick google says yes its OK, the voltages are the same. probably a different lead is all that is required.
My sister, when she emigrated to Australia, was able to use her comp without any problems out there, so I would think the reverse would be true...
Ok,
if I plug it all in and then power on can I kill the pc or will it just not power on
If anything is going to blow it will be the PSU which will be protected by an internal fuse if it's decent. You probably do need a new 'kettle' cable, I assume the input socket on the actual PSU has three prongs? That should be standard.
Andi.
