Using a router as an access point only
31 May 2005
Nottingham
First off, I am a cheapskate.
I have an old but reliable Linksys 54GS running Tomato firmware.
This router is only 54G speeds.
I have a Netgear WNR2000, which is pants.
Now, if wanting to use the Netgear as just a wireless access point giving me Wireless N speeds., I assume I just disable DHCP on the router and hook it up to the Linksys.
Does the cable from the Linksys goes into the WAN port on the Netgear?
To summarise, I wish to use the stability of the Linksys with Wireless N support from the Netgear.
Many Thanks.
The easiest way to do it is to disable DHCP and plug the WNR into one of the Linksys via the LAN ports. The Netgear might have a setting that allows you to use it as an AP via the WAN port but the easiest way is via the LAN ports.
What most people call a router is actually a router, a switch and an access point in one box.
Thanks.
Have got it connected up, although is only connecting at 54Mbps.... even though it is a Wireless N router and a Wireless N adapter..... ?
It is Windows Vista.. Installing Windows Updates now.
Different ssids or just disable the wireless on the gl completely.
If I were you, I turn that netgear over and check the revision. V2 can run tomato k26 builds (i.e. teddybears) but it really depends how old it is.
