- 24 Aug 2009
Hey guys, the situation is,
I will recieve a set of home plugs tomorrow. One of them will be downstairs connected to the wireless router, and the other home plug will be connected in my room upstairs. I was going to just connect it straight into my pc but it got me thinking
Is it possible to hook the second home plug (upstairs) into another wireless router to use it as an access point and a switch so we can have a strong wi fi connection throughout the house?
Or do you have to buy an actual access point to do this?
Thanks.
Is it possible to hook the second home plug (upstairs) into another wireless router to use it as an access point and a switch so we can have a strong wi fi connection throughout the house?Or do you have to buy an actual access point to do this?
Thanks.
You might also want to turn off NAT on your router. Also, make sure you have A) A ethernet cable to access the router just in case you get the config wrong B) Know where the reset button on it is, and know the default username and password for it.. just in case.
