- 6 Aug 2009
- Wales
Hi all,
quick question if i may, first though this is my current overclock:
4770K @4.6 via multi (46) cache ratio (45) vcore @1.3v adaptive.
Corsair vengeance pro series 1866 @2133 9-10-10-31 1T
As you can see i've overclocked my system using the multiplier, but recently read a few topics that talk of using a strap to overclock too.
I've had a google for info and tbh it's a little confusing so was wondering if you guys could help explain the Pro and Cons of using a strap when overclocking.
Most i've been able to get out of my cpu is 4.8 @1.4 but temps using my H100 started going south of 75c so decided on 4.6 as my 24/7 overclocked.
I did read that a strap can help get the same overclock but will less volts, and as i'm still saving for a waterloop, i thought i'd ask to see if this is the case.
Cheers for any advice or info.
David.
David.
