using a switch?
Man of Honour
29 Jun 2003
Wiltshire
A switch won't give out IPs automatically, so you will need to set one for each computer (within the same range). i.e. 192.168.0.1 / 192.168.0.2 / so on :)
23 Jun 2005
Nottinghamshire
yes, Duke is correct, a switch wont come with a dhcp server built in so you will need to assign ip addresses to each of the pcs. as far as im aware this will in effect set them up as a workgroup.
if you want to share files and folders make sure you enable simple files sharing and you may need to configure any security software on the pcs to allow access
