Using ext sd card as internal storage marshmallow
27 Jun 2008
I have been reading that you can use ext sd card as internal storage but as it encrypts the data you wont be able to read the sd card in a computer etc. I have ordered a 128gig micro sd so i am wondering if I can creat 2 partitions on the ext sd card about 64gig in size each. I am thinking the phone could use 1 partition as internal storage and the other partition as a normal ext sd card. Is this feasible ?
Based on my limited experience probably not. When you insert a MicroSD card the first time in a Marshmallow, non-Samsung phone you have the option of choosing whether to use the card as internal or portable storage, it'll then be formatted.
With a Samsung phone you don't have the option of using a card as internal storage.
