Caporegime
- 13 May 2003
- Warwickshire
Hi all
1650 Super user here with what I think is a fairly niche use case?
I basically need to get both HD audio into my receiver (Yamaha YSP-2700) from DisplayPort and Gsync-friendly UHD graphics from HDMI into my LG CX OLED from the same GPU at the same time.
This will allow me to have the maximum graphical and audio goodness possible, without having to buy a next gen GPU with HDMI 2.1 and a new receiver with eArc.
My 1650 Super, which is being used in my HTPC, only has one HDMI output, so before I buy a cable / adapter that converts DisplayPort output on the GPU to the HDMI input on the AV receiver, will this work?
I believe DisplayPort carries audio, so the only question should be whether the same GPU can output video and audio to different destinations at the same time, yes?
Thanks!
Thanks!
Like yourself quickly found duplicating and disabling does not work. Fortunately used to it now having had this method in use for 5 years now. In Nvidia control panel I make the monitor representing the AVR absolutely tiny in NV control panel. I then position it in an a corner which means your not often going to go off the screen, if you do its at a very precise spot and even if you do manage it, the AVR screen is so small, your mouse wont travel too far before hitting its theoretical edge. Like so:
