*explodes*iBot said:You like that huh?
This will probably float your boat then
To really take care of your hearing you have to rest your ears periodically. You shouldn't use headphones for more than one hour at a time, because the constant exposure to sound waves generated so close to the eardrum will eventually damage the delicate lining of the ear.iBot said:Anything elsei should be aware of?
Arcade Fire said:Every hour, stop using the headphones and get hold of a small pepet, which you should fill with olive oil. Drop 2-3 drops into your hear with your head tilted away, and use cotton wool to plug the gap. Leave it in there for about ten minutes, then remove the cotton wool and use a clean cloth to remove any excess oil from your ears. This helps to regenerate the lining of the ear and keep everything nice and lubricated. Then you can listen away again.
Yes, that's another advantage of lubing up your ears. If you can't get olive oil, then use vegetable oil. For christ's sake though, don't use WD40. That stuff is meant for robots.William said:When its lubed up the sound travels faster too, so it sounds better.
Arcade Fire said:. For christ's sake though, don't use WD40. That stuff is meant for robots.
Arcade Fire said:Yes, that's another advantage of lubing up your ears. If you can't get hold of any olive oil then you can use most other well-known lubricants. KY Jelly actually works surprisingly well, but you have to apply it with a cotton bud instead of a pepet. For christ's sake though, don't use WD40. That stuff is meant for robots.
-White-Knight- said:Putting lubricant in your ears? Are you sure that's safe? Sounds dangerous!
See my edit. You should edit your post to reflect it.-White-Knight- said:Putting lubricant in your ears? Are you sure that's safe? Sounds dangerous!
ElRazur said:I think it aids penetration*
*Audio penetration that is.
-White-Knight- said:Joker! But surely if you get it on your ear drum then it will make sound distorted?
n00b.-White-Knight- said:They look like they'd be very tinny etc
punky_munky said:I think you're getting confused between ears and eyes.
ElRazur said:Personally, i wouldnt try an advice like that, i am almost deaf in one ear and i would take a risk of losing the second one. As it is, i find it hard speaking english language properly hence sign language will even be more difficult.
I dont put nothing in my ears apart from cleaning them and using headphone (not the sonar ones as posted by the Op) when in the studio and listening to my sony mp3 player.
Feek said:n00b.
Seems to me that most people in this thread are taking the **** because these cans look old.
New does not necessarily mean good. Just because something is old doesn't automatically make it crap.
K.
