I'm a designer and I use a mac because apart from looking nice, OSX is so much nicer to use day-to-day than windows.
Panzer
I've used Windows for the past 10-15 years and much prefer how OSX.
I am thinking of learning to use indesign a little bit to make brochures, why do designers use Apple Macs for this work?
Is there any real advantage over the windows versions?
I have a complete set of Lynda.com videos that I am going to have to work through, and the guy is very annoying to listen toHope that helps, and have fun learning Indesign, its an awesome app.![]()
If you've never used windows before perhaps. To me osx is a pain in the ass to use, simply because ive not used it much.
Also don't forget stability issues. Macs are more stable, time is money!
That's the key thing for me really - spend forever tweaking Windows to get everything just so or use OS X and just get on with it.
The productivity of workflow probably doesn't change between the two platforms but it's all the time in between that you would be faffing with Windows that makes the difference.
Panzer
