using nvflash to flash 2nd cards bios
Permabanned
5 Apr 2006
Hi
What commands do I enter into nvflash to make it flash my eVGA 8800 Ultra with the Asus' bios while having both installed at the same time.
I can't be arsed taking them out of the system lol.
nvflash -4 -5 -6 filename.rom
That will flash both cards one after the other.
Thats a good thing as you will be sure then both cards have identcal bios's
You will need to press y a few times.
PS
Have you made sure that both the cards can run the core/memory clocks in your proposed bios ?
cheers, I found out I have to enter it as "nvflash -i1 -4 -5 -6 g80.rom" -i1 being the 2nd card.
I'm not flashing an overclocked speed just putting the Asus bios(newer) on the eVGA card.
