Hi, roughly its your voltage at idle speed taking from your overclock voltage.
My 4820k at idle 1.248v at 4.6GHz needs 1.344v > 1.344-1.248=0.096v, this will give you a starting point
it may need more volts or even less to run my build is x79 mine needs less 0.085v..
so i take i reset bios to stock take vcore setting then add my multiplier and any other adjustments i had except manual vcore use offset instead.
on my 4,5 i was using llc ultra high.
