My bad, wrong choice of words.first of pfSense is not a modem
Aquiss.What ISP are you going with for FTTP?
I am aware of their questionable ethics.You really should do a little bit of research into pfSense, they are not a very nice company by all accounts.
Yeah, I have that so should be good to go.Looking at Aquiss' website they have a handful of guides to configure routers, looks like they use PPoE for FTTP.
Aquiss - Router Setup Guide : TP-Link Archer AX20 / AX23 (AX1800)
support.aquiss.net
So just ensure you have your PPoE username and password details ready and you'll be fine.
It's literally an optical to coax converter.Why does the ONT not handle the authentication though?
I'm with Aquiss, the username/password is in your ebilling portal. Literally any firewall which supports PPPoE should work.
None, I wish I'd have discovered them sooner.Any problems with them as an ISP?
), so I'm looking at getting a pf/opnsense box to act simply as a PPPoE modem/bridge.I get 920/110 with my UDM SE.so it turns out that UDM Pro Atom CPUs can't handle gigabit-speed PPPoE encapsulation
Interesting, aquiss do offer that.I get 920/110 with my UDM SE.
If you want to pass through a line so to speak you’ll need to take out multiple public IPv4 addresses.
