- 4 Dec 2012
Hello guys...
I haven't used RAID before so have little knowledge with it, anyway as any normal person would do I started researching about RAID and learned what different arrays do, but I'm having a problem deciding between using RAID 0 with RAID 1 or just RAID 10? as I understand RAID 0 is striping data across 2 drives which basically means its the best performance array because data is read/written to both drives, though the downside is no redundancy which basically means if one drive dies you loose all data, so in this case I thought RAID 0 would be good just for my games, and then using RAID 1 for my operating system as this array has no striping so all my data will be safe if 1 drive dies, with the benefit that Read performance is improved since either disk can be read at the same time, meaning if one disk is busy the other is accessed, sounds great for windows in my mind, and then RAID 10 which is apparently the same as using RAID 0 and 1 together this is where my problem lies, as RAID 0 and 1 would use 4 drives so would RAID 10, what is better? am I just over thinking? or is there any beneficial difference between these 2 arrays?
