Using SSD as boot drive in new build
16 Mar 2012
Newcastle
First build so go easy!
So just ordered all the stuff, and using a crucial m4 64gb as boot drive and a 500gb WD as the other. I just wanna use the SSD for the OS and a few regularly used programs but how do i go about doing this?
Do i simply just plug in the SSD to begin with, install OS and then add the 2nd HDD? Also is there anything else i need to know?
Thanks and apologies if this has been asked a thousand times!
Dan
yer simple
or keep an os on the other hdd and multi boot depending on what you do
so you can choose which drive to use
my multi boot is currently
win7 ssd
win7 64 hdd
win vista 64 hdd
win xp32 hdd
ubuntu 64 hdd
and soon its having
mac os lion hdd
soon as i can get the damn thing loaded..
but link to stuff from your ssd that you dont use often on a hdd and for gerneral stuff boot to it also
then only boot to your ssd when u need to as its a small one your getting
easy bcd if you want to multi boot its better than going thru bios tbh recomend it 100000000%
Enable ahci in bios before installing the OS on the ssd
depends on your set up and how many os you have that
mine wont boot into other drives if i enable AHCI theres a lot of pro and against arguments still as to the benefit of that but on my system i cant boot into other drives with it. so i guess it depends
most will say its faster in AHCI mode tho
1) Change storage to AHCI in BIOS (dunno why you wouldn't be using this in the first place though)
2) Unplug old HDD, Plug in new SSD to first sata port
3) Install W7 64 to SSD from DVD or download as per above.
4) Install all important system drivers (chipset, graphics, Intel RST).
5) Open RST in system tray and check that disk data cache is enabled
6) Disable file content indexing (optionally turn it off completely) for SSD and double-check that Windows has correctly disabled scheduled defrags for SSD
7) Run WEI
8) Plug any other HDD in.
