using thermal epoxy
30 Dec 2007
Oxonfordshire
Ive just bought the accellero S1 and attached it to my hd4850.
brilliant and happy with temps:D
but the mini heat sinks that came with it had sticky pad that your suppose to peel and stick to memory etc, the thing is they aint that sticky!!!
would using thermal epoxy be an idea or is there another way to keep them stuck on.
they are on now but i dont see them lasting
The ones I had on my 8800gt periodically fell off, despite me cleaning the ram with acetone.
Thermal epoxy will do it yeah, very definitely. You won't be taking the heatsinks off afterwards though. Perhaps buying some adhesive thermal tape and using that would work better?
