Hello all,
I'm very much a noob when it comes to paying attention to cooling and fan settings etc.
I've just built a new PC with a Ryzen 3700x, 2070 SUPER, MSI mortar max etc inside a Fractal define mini c case. I've just replaced the stock fans with 3 corsair 120mm RGB fans, and i'm using the stock cooler on the CPU.
The CPU is actually idling at about 55-60c which seems wild really. I've reapplied thermal paste and it actually seemed to make no difference at all.
The other issue I have is the fans are just being volatile; just spinning up and down at random times, even at the click of a link in Chrome, or at the first sign of any drive usage etc. What am I doing wrong?
I can use a custom curve in the MSI command center software but dropping the RPM on the system pumps the temps up on the CPU to mid-to-high 60s, even touching 70c.
I also downloaded SpeedFan as i'd used that before for a much earlier build I did, and strangely none of the fans are being picked up at all. All it sees is my hard drives.
Just a little disappointed as the noise and temps are putting me off actually using the thing currently
Any help will be very much appreciated
