UV filter results in soft images?
You can also not spend and just be careful, and learn to clean glass properly. I just can't understand spending £100 on something to prevent /you/ from being an ass and plonking your fingers on the glass. Doh.
As for protection from shocks, well, a thin /hard/ filter will shatter immediately at the slightest shock, and the pieces will be right next to your front element. Do you want small pieces of hard coated glass rubbing against your front element ?
/Lens/ glass doesn't shatter that easily, it's 'soft' glass with a lot of heavy elements in to improve it's refraction index. So it's actually quite hard to break a lens, you could cause separation of groups due to mechanical shock -- but a filter wouldn't help there anyway.
The net is full of stories with "filter saved my lens" (ie when the lens was dropped etc) but actually in these stories, what happened is these guys were /lucky/ that the shatered pieces of filter glass didn't go and mangle the front element. THATS the true story there.
So, there are zero reasons to use a (non pictorial) filter. It's an urban legend, kept on an on by 1) manufacturers of filters who make a HUGE amount of money on snake oil 2) the desperate need for photographers to accesorise. Snake oil makes you feel better therefore it /has/ to be good.
Just calculate it; look at the price of a 'super duper' filter versus the price of a great /lens/ like for example, a Canon 85mm f1.8 (£200+). The lens is worth barely 3 to 4 'filters'. Doesn't it sound /wrong/ to you ?
People like touching things, so it's better for them of touch that cheapo UV filter (that doesn't have a HUGE impact in IQ aside from flaring in direct light) than for them to touch my £400 lens, regardless how durable the front element is (and I do know how durable they are, my 18-135mm doesn't have a filter and I've even cleaned the element with my shirt, not a single scratch on it).
Or just use decent filters like the B&W F-pro ones I use, which have no effect on the image. I like the security of having the front element sealed away from the nasty outside world.
where did you buy the f-pro filters? i might be after a new 77mm CP for my 17-40 & 24-105 - my current one gives me terrible vignetting at the widest angles on the 5D
personally i dont use UV filters - as said even once the front element is clean and had placed the filter on i would check it a couple of days later and there would still be dust between lens and filter.
the only filters i use now are the effect filters - e.g CPL GRADs ND's
*snip*So, there are zero reasons to use a (non pictorial) filter.*snip*
You mean in your experience? I f the lens glass is so resistant (Which I agree it is) why shouldn't you be scared of dropping and smashing the lens, but you should be scared of little pieces of glass hitting it?
Also I have experienced situations where the filter saved the front element from damage and scratches. If you prefer not to use filters, then that's your choice, but don't say its 'It's an urban legend'. because from my own personal experience it's not.
