- 1 Apr 2013
- Dundee, Scotland
I have over clocked I have gotten to 4.5ghz on an i5 3570k with 1.280 volts and after just 6 minutes my temps are 78 (on OCCT) degrees I bought this cooler as it was supposed to be performance and its not performing I have tried re seating the block twice. and bleeding the system by rocking it back and forth laying it on its side and even turning the case upside down while its on to get out all air.
customer support says to post in here as they say its and over clock issue and 8 is their resident specialist
I have the V8 water cooling kit with a hardware labs 240mm x 54mm deep rad that i got as an free upgrade.
customer support says to post in here as they say its and over clock issue and 8 is their resident specialistI have the V8 water cooling kit with a hardware labs 240mm x 54mm deep rad that i got as an free upgrade.
