Vapochill LightSpeed Mount Kit
10 Oct 2013
London , UK
Hi all!
I don't know this the right place for this thread,if not i'm really sorry.
But...
I'm looking for the universal mount kit for my Vapochill LightSpeed Evaporator.Or i'm looking for someone who know where can i get one,or someone who can make that mount kit for me.
Universal means:
- Intel socket LGA 775
- Intel socket I7; LGA 1366
- Intel socket I5; LGA 1156,1155,1150
- Intel socket i7; LGA 2011
- AMD Socket 740
- AMD Socket 939
- AMD Socket 940
- AMD Socket AM2
- AMD Socket AM2+
- AMD Socket AM3
- AMD Socket Athlon 64
Many Thanks!
There is no such thing as a universal mount kit for the Vapo. A different mount block was required for each different socket type. Duniek used to make them, so might be worth getting in touch with him if he is still building.
Failing that, Piotres in Poland may be able to fabricate a universal Clamp down head for the evap.
I will point out though that a Vapo Lightspeed will struggle to hold negative load temps on any CPU with more than 2 cores. 4 cores under load will crash the Lightspeed.
They were never designed with anything much more than single core CPU's in mind.
Thanks for your post.
Few years ago i had another evapo.
I've been use for quad cpus without any issue.
Now i've got again one of ths evepo,and i want to test a lot of processors.
At the moment i want to use for the new intel cpus.
So i just hope i can find anyone who can make mounting kit for the intel processor.
Thanks!
