Vapor Condensation Inside PC
9 Jan 2011
Hereford
Hey guys,
I've got an issue that is starting to bug me.
I like to vape next to my pc but i have started to notice droplets of vg dripping from the radiator/fans sometimes this end up on the case other times it can be the graphics card.
I literally have to get some tissue to clear it up because it looks like a small puddle.
Anyone have any idea's on how i can reduce this?
Your pc tends to filter the air, same thing happens with regular smoke except its depositing the tar as the smoke cools.
The only thing I could think of is to deliberately put actual filters on the intakes of the pc and keep checking them.
Vaping is horrible. I feel like I'm drowning with all the fluid that ends up in my lungs. Garbage Chinese invention (it really was invented by the Chinese) also the carcinogens in vaping have been proven WORSE than normal cigarettes. Go buy a pack of camels and call it a day. Smoke them outside ;)
Or simply pack it all in. You be healthier and your PC will smell better and be cleaner :)
LOL - sound advice - makes me laugh when you consider these forums are all about maximizing the performance of your PC system and here we have someone who insists on spraying his with moisture and wondering why it has condensation! - unbelievable.
Yeah, no. This is complete BS.
No it wasn't.
The big difference being that PC is easy to replace, unlike lungs.
The difference being, the lungs have a mechanism of dealing with fluid, absorbing and breaking it down.
The major components in electronic cigarette vapour is the same as the those in smoke or fog machines. It's very well understood.
Probably best to flush the vapor out with a bucket of hot soapy water.
You should do this with the PC on and the fans spinning at maximum speed to ensure good distribution of the clean water.
Buy a dehumidifier. Vape is just tiny droplets of water floating in the air, like on a foggy day or if you're in a 'steamy'* kitchen. I live in a flat and a dehumidifier is the only way to dry washing and the bathroom after a shower. Mine collects over 2 litres of water out of the 12hrs its on over 24hrs. Not vaping or smoking > vaping > smoking. Your PC must be cold, try playing some games and get that thing heated up :)
*tiny droplets of water suspended in air
