Vaseline on the door seals - when is it worth it?
Hmm, I'll be doing that for my sunroof then :p
I was more thinking with regards to cold weather - is it a good idea to grease up the seals if there's frost and the doors are sticking?
Use a water based lubricant, not Vaseline as it will dissolve the polymers in rubber. It also applies for "rubbers" if you know what I mean.
Sillicone based grease from anywhere should be ok.
I used some spray stuff from Halfords when my roof started leaking and it's not done it since :)
