- 6 Jun 2011
Hey guys,
So I have finally been able to get out and have a look at the car. We basically took off the large rubber pipe with the two bolts. This then revealed the butterfly which we cleaned using a clean paint brush and brake fluid. Is this correct?
Here is the outcome:
BEFORE:
AFTER:
With regards to the EGR valve I am still having trouble locating this. I have a couple of pictures which I hope you guys can tell me if it is actually there anywhere?
This picture is what I think it is more likely to be:
Cheers
BEFORE:
AFTER:
Cheers
