vb sqldatasource and passing identity to query
8 Mar 2005
London, UK
I'm trying to pass User.Identity.Name to a sqldatasource where query in vb asp and as always getting in to a pickle.
On page load I have the following to set up the parameter.
Code:
   Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        ' When your page opens, set your datasource parameter '
        ' SqlDataSource1.SelectParameters.Add("@UserName", User.Identity.Name)
        SqlDataSource1.SelectParameters.Add("@UserName", HttpContext.Current.User.Identity.Name.Substring(HttpContext.Current.User.Identity.Name.IndexOf("\") + 1))
        Message.Text &= "User NameNoDomain: " & HttpContext.Current.User.Identity.Name.Substring(HttpContext.Current.User.Identity.Name.IndexOf("\") + 1)
    End Sub
in this instance; I'm stripping out the domain as I just want to pass the userid. I'm now having a brainburp in passing that to the sqldatasource.
Code:
        <asp:SqlDataSource ID="SqlDataSource1" runat="server" ConnectionString="<%$ ConnectionStrings:blahblah %>" SelectCommand="SELECT blah FROM blahland WHERE (userblah LIKE '%' + @UserName + '%')">
           <SelectParameters>
                <asp:Parameter DefaultValue="@UserName" Name="Username" />
        </SelectParameters>
        </asp:SqlDataSource>
I suspect the code bahind isn't feeding to SelectParamters in the way I expect but I've tried various means and way and syntax's and not getting very far!
Any pointers would be greatly appreciated!
TIA!
Could just be the name of the parameter? You've got 'Username' here:
Code:
<asp: Parameter DefaultValue="@UserName" Name="Username" />
and 'UserName' here:
Code:
SQL is case-sensitive so might not be finding the parameter you set?
I think I've sussed it; a proper brainburp!
Code:
SqlDataSource1.SelectParameters.Add("UserName", HttpContext.Current.User.Identity.Name.Substring(HttpContext.Current.User.Identity.Name.IndexOf("\") + 1))
Removed the ampersand and remove the defined sqlparamter.
Code:
Now works as expected!
Cheers!
