Hello - I would be very grateful if anyone is able to offer me some help - I should start with the fact I am not particularly technical.
I have been having intermittent dropouts with my VDSL connection and my ISP sent me list of things I should do before they would raise a ticket with BT (the line check showed no faults - just lots of drop outs).
One of these things to try was to replace the filter being used. I don't have a plug in filter as it's built into the faceplate, so I purchased a new faceplate. I was under the impression it would simply being a case of taking the old and replacing with the new one, but when I removed the current faceplate I noticed 2 things:-
1) The orientation of the block where the wires go in was horizontal in the existing faceplate and horizontal on the new one (I guess this probably doesn't make much difference).
2) There were no wires going into the faceplate on the existing plate - they instead go into the back part of the box.
For now I've returned everything back as it was as I wanted to get a view on whether this was a normal setup.
I've attached a couple of pictures.
1. Is the back part of the old faceplate where the wires go in 2. Is the reverse of the old faceplate 3. Is the front of the old faceplate 4. Is the front of the new faceplate 5. Is the reverse of the new faceplate
