Straight Veg from anywhere thats cheap + 10% white spirit is what i run the Citreon on and thats been for the last 6 months.
What engine is it ?
Don't run vegetable oil on a Common Rail deisel. The injectors aren't cheap!
To be honest I wouldn't run it in any engine. It has a nasty effect on engine oil and fuel dilution can reach 20% in the sump.
Im sure you can imagine the effect this would have
you can spot a car running it too. The smell out of the back. It will also fry your HP pump (regulator seal predominantly) as well as your injector(s).
Ouch for the bill
Customs would love to get their hands on you then, white spirit is a "tied" oil, not legal for road use in any way.
Do NOT run it in a common rail system, you'll shag it pretty quickly.
Yes, you've told me that before and i still already know that.
but hey ho.
A splash of unleaded will do just as well.
