Velux blinds automated on a timer?
22 Jan 2014
Evening OcUKites,
I've been looking for a means to have the Velux blind automatically rise on a timer i.e. in the morning to enable blackout in the night and then to let daylight in in the morning as a form of alarm.
I've only found remote control options and fully automated window assemblies, rather than a blind assembly with a timer function. Please note the blind isn't on a pull cord, but rather integrated into the window.
Any pointers?
Sorry thought you meant it was already electric
Though similar question then
Where will the blind get power from
As if got to be wired in would think a timer could be done at same time
And still want one of those automated blonds lol
You can buy Velux blinds with remote controls that use a solar charged battery pack, so I'm hoping for similar but with a timer function
Didn't know about solar ones
Not really something I know much about to be honest
But having a timer
Or a light sensor
Seems a pretty sensible idea
Some one with more knowledge hopefully will answer
Can't see why you could not splice in a timer or light sensor though
Depending if you are the DIY type
IKEA now have electric blinds and controllers that tie into home automation ecosystems. Reasonably priced IMO. But not sure they'd work or fit on a roof window.
Just had a look - they may actually solve another issue, being that when the window is open with integrated blinds, the open area is of course no longer covered by the blind.
The ones you're referring to would hang separately and thus let air circulate whilst also blocking almost all of the light. Ideal!
Only problem is, the size I'm after appear to not be available in any IKEA store for collection, and they will not deliver anywhere. Very odd.
I'll keep an eye on those as they could be even more perfect than my original plan.
Yes to being into plenty of DIY stuff, but I tend to avoid electrics! Definitely worth considering though.
Yeah me too as for mains electrics
But assume solar would be low voltage
And since separate can't blow/trip any fuses
And lived in a place once was a conversion so all the windows were angled /velux
With the IKEA style mentioned I found they didn't block enough light~depending what angle the sun was~and they flapped around too much in a breeze
I used some sort of clips I had laying around so when necessary could have them either hanging down or clipped on so parallel with the windows
