I have bought a 120GB Vertex 2 but when I connect it to a SATA port the BIOS will not see it, the machine hangs a while before the BIOS.
I have tried different ports, setting mode from IDE to AHCI, only connecting the SSD, resetting BIOS and now I am lost.
Should there be an issue with my old MSI Neo2-FIR P35 mobo even though it has SATA-II ports?
What else can I do or is it RMA time?
If the controller chip does not get power or becomes damaged then the SSD does not exist as far as the BIOS is concerned. It happens with the best of SSD's but stick to OCZ.
