Vertical line through middle of screen
8 Sep 2006
Hey guys,
I recently bought an Alienware AW3423DWF (awesome monitor btw!) and am seeing a vertical line down the middle of the screen, but only with my PC and on any interface.
It mostly visible on grey or lighter images when gaming, but is visible during general desktop use with similar colours too (sublime notepad for example).
To rule out the monitor panel being the issue I have tried a different DP cable, different interfaces, but ultimately it seems to be something associated with my PC itself. I have the PC connected to DP1 and a laptop on DP2. The laptop does not have the issue regardless of the port that it's on. I haven't tried the HDMI port because I have a Playstation connected there (and will remain there).
I've tried updating the graphics card drivers, downgrading to older drivers from last year, adjusting the refresh rate of the monitor (in case is was something freesync related), but still the issue remains.
There is a self diagnostic mode on the monitor that appears to filter through numerous colours (starting with grey where in game or desktop I see the issue most), but there are no abnormalities that I can see so it does not appear to be burn-in.
I'm thinking this is something graphics card/drivers related, so just curious if anyone here had any suggestions as to what this could be please? PC spec is below just in case it's of any use:
AMD Ryzen 5 3600 (stock, no OC)
Crucial Ballistix 16Gb @ 3200Mhz
Gigabyte Eagle OC 3060Ti
Gigabyte Auros Pro B450 Wifi ITX
Corsair SF750 PSU
Crucial P5 Plus 2TB M2 NVME
Thank you!
Hmmmmm very odd and annoying especially with only 1 HDMI. Only thing I can think of is, whilst both DP's say upto 1.4, in the monitors OSD have you changed it away from 1.2 being selectable? Force it to only be 1.4? What gfx card is in the laptop?
Well, if you've tried all the ports with the system and it's showing this, and it's not exhibiting the issues with other systems, my first thought would be; faulty VRAM (or possibly even the GPU core) which doesn't normally show up, but has now because it's being driven harder to display more resolution on the larger screen of the DWF.
Have you tried with a different GPU output from the same system? Onboard GPU? Or another discrete GPU? That should tell you if it's the GPU in your rig right now (3060Ti) that's got an issue, or if it's something else.
Horizontal or Vertical LinesScreen has one or more lines.When using DisplayPort input, the positioning adjustments are not available.
Did you get the drivers and stuff from here for ur mon, they may be needed.
Someone sounds like they had the same issue and states a temp fix.
another saying its the dark stabilizer option. also read DiAvOl-gr reply there too.
grey uniformity section.
Thanks for all the help, guys! It appears that since I original researched the issue there were new reports of it and thanks to Skeeter, it's now sorted :D
It was the Dark Stabilizer setting. I have changed it to 0, but simply just changing the setting from the original setting of 1 to something else and then back to 1 sorted it too. So I guess like has been mentioned it's probably temporary, but I'm cool with that as it's at least a way to sort it out.
Thanks again guys. I had been looking in to for ages and 1 day after a post here it's sorted lol. Good old OCuk forums!
wonder if its got a firmware update to fix that tho it says those types of monitors all suffer in some way or another so i dunno but glad u sorted it. :)
There is a firmware update, but it doesn't seem to be for multiple issue fixes. Seems it's for HDR only; but hopefully there will be additional ones to sort stuff like this. Thankfully the updateable firmware is a great feature on this screen! But yea, these kinda screens do suffer with weird issues :)
Incase anyone else has this issue. This came up for me randomly. I got rid of it by doing OLED Panel Maintenance > Pixel Refresh. Seems like all the proposed "fixes" are silly.
