Hi all,
I purchased a Samsung S32D850 32" 1440P monitor last month or the month before from OcUK.
In some games the screen will flicker a bright grey colour with vertical lines running the height of the screen. Now this happens in multiple games such as Far Cry 4, Dayz, Arma 3, WoW and The forest.
Looking into the sky I get no flickering at all. It sounds strange but it only seems to do it when you focus on grass or some form of foliage.
Things I've tried include:
Updating CCC
Installing monitor driver
Switching between DVI and display port
fiddling with monitor colour, contrast, response times etc.
Adjusting GPU clocks and voltages.
I should mention that I have a second 1080P monitor that I have used for years and had no problems prior to using this monitor.
Any ideas what the problem could be?, I'm beginning to think that perhaps the monitor is faulty.
Thanks in advance
Updating CCC
Thanks in advance
