Vertical mount
Hi, I have a Rtx 3090 founders edition and I want to vertical mount it, what's the best way? Tia
What case do you have? Some kits are case specific. You’ll also need really good ventilation and the incoming case airflow doesn’t.t reach the card as well when vertically mounted.
