Very annoying graphics problem
2 Jan 2012
Hi everyone,
Specs as follows:
i3 2120
ASRock Z68 Pro3
8GB DDR3 1600MHz
Onboard graphics (HD 2000)
OCZ Agility 3 60GB
OCZ ZS 550W
Windows 7 Ultimate 64-bit
Just got my rig together and installed all the drivers, but CPU-Z is showing my Graphics Card as Intel HD 1000 (GT1), however Intel's Driver Update Utility says I have got Intel HD 2000 and that I have got all the latest drivers.
I am also having another problem in After Effects CS5, which I think is related: when I try to view the image as Rendered when using the Shatter effect, I get error messages in a row:
First:
"After Effects error: crash occurred while invoking effect plug-in "Shatter".
Second:
"After Effects error: Crash in progress. Last logged message was <2064> <DynamicLink> <5> C:\Program Files (x86)\Common Files\Adobe\dynamiclink\CS5\dynamiclinkmanager.exe
Third:
"After Effects can't continue: sorry, After Effects has crashed. See http://www.adobe.com/support/products/aftereffects.html for known issues. If you still can't resolve this issue, please contact Adobe Technical Support (2).
( 0 :: 42 )
It then asks me if I want to save.
When I go Edit > Preferences > Previews > OpenGL Info, it says "No compatible OpenGL graphics card found." But Intel's website says that Intel HD 2000/3000 have support for OpenGL.
What is going on here!? :confused:
