Problem: Terrible Speakers.
Solution: replace with KEF Cresta 2.
Some specs:
365 x 205 x 240 mm.
Frequency response ± 3 dB 48Hz - 20kHz
Sensitivity 90dB
Amplifier requirements 10 – 100W
WOW, is all I can say. These speakers have some serious bass. They're even near a wall; despite being rear ported, and on a flimsy shelf (till I'm back at uni), and the bass is very deep and powerful.
They're also insanely loud compared to the others, 1/4 volume is roughly equivalent to 2/3rds on the old speakers.
They sound absolutely beautiful to me.
Cost? £50 on ebay. They sound so full, and are absolutely perfect for my listening taste.
I think I've unearthed a bit of a gem here. Not much about them on the web, save for:
http://www.kef.com/history/1990_2/cresta_1999-02/cresta2.asp
http://www.audioenz.co.nz/2001/0201.html - review
I'd definitely recommend them for people looking for bassy bookshelf speakers on a budget. With Loudness on there's not much less bass - if any, than the sub that came with my old 5.1 system. However, it's much more "there", and blends with the music much better.
Now I'm just tempted to get something like a NAD C320bee to treat them a bit. Would you guys recommend this amp, and what kinda price should I expect to pay on ebay? I heard they sound similar to the NAD 3020, which my mate has, so I can try them out with that to guage the sound, but wouldn't mind the extra power now and then of the 320 and the remote wouldn't go amiss either. Are they reliable etc though?
Thanks
Some specs:
365 x 205 x 240 mm.
Sensitivity 90dB
Thanks
I just turn loudness on as I rarely crank them up properly, so it sounds better with it on. When I turn it up I turn the loudness off
