- 11 Jun 2014
- Lancaster, UK
As you've had it that long then you won't be able to return it unless the seller has a very generous returns policy.
I believe you can only SLI with another 780 Ti.
I think 6GB versions will be available in the future but you wouldn't be able to SLI with one of those as the cards need to have the same amount of VRAM.
Just to check is your motherboard SLI compatible?
What's the spec. of your system?
Windows 7, Home Premium 64 Bit
Intel Core TM 2 Extreme CPU X9650 , 3.00GHZ, Memory 8192MB RAM, Direct X 11, Nividia Gefroce GTX 780TI - Single one of those for now, Monitor 2560x1440 (32bit) (59Hz)
