Very odd Booting behaviour - help!
5 Jan 2004
I’m not sure which forum to post this in so I’ve cross-posted in Hard Drive and Windows OS forums. So….I have some very strange behaviour on my computer at the moment and I think I know the root cause, but I’m unsure on the safest way to proceed. I’m running windows XP home edition, but I have a previous corrupted install of windows XP pro lurking in the background (on a hidden partition I think) which is causing a problem and I’ve not been able to remove (because I can’t see the partition in windows).
The symptoms: computer refuses to boot and stalls at windows XP screen. In safe mode it also refuses to boot but returns a windows XP Pro error – the OS which is lurking in the background. When I remove the HDD, try and boot, then add the HDD back again the computer boots normally.
So, it looks like I need to remove the old corrupted windows XP Pro partition so that it recognizes the XP home OS and boots accordingly. The question is what’s the safest way?
The choices: I have Norton utilities which could try and repair the partition using Disk Doctor. I’ve no idea if this will work, but I could give this a go. Will it recognize the problem and remove the old partition or merely try and repair it. I’ve no idea how Norton Disk Doctor works.
I also have the windows installation disk which I could use to hopefully recognize the hidden partition and delete the partition. I’m not sure how this would work – do I simply try to reinstall windows and it will give me the opportunity to format the hidden partition?
So which strategy is best? I’ve copied the ‘My documents’ folder onto a second HDD so I have my important docs backed up. Are there other folders I need to copy?
I should think that if you run the windows XP install from the CD and select the 'repair an existing installation' option, that should take care of getting your system running again.
To delete the old hidden folder, once in Windows, go to 'my computer', highlight the hard drive, select 'tools' from the menu, then 'folder options', 'view' and then select the box which says something like 'show hidden files & folders'.
You should now be able to locate and delete the old installation.
I hope that helps.
