Very odd connection problem.
8 Jun 2005
United Kingdom
OK firstly I would like to add I am not joking before I start!
I ordered SKY Broadband a few weeks ago. My line was activated on the 11th December and I finally got my Router on the 16th December after some trouble with ParcelForce.
So Tuesday night I connect everything up but I get a DSL problem. After resetting the router everything works OK for the rest of the evening.
Now, yesterday I come home from work, turn the PC on and same DSL issue. I try to reset the router and this time nothing works so I end up ringing SKY Tech support (Hardly tech support imho!).
1 minute into making the phone call the internet starts working and I think typical timing just as I get through to someone the internet works, so I explain what just happend and hang up. 1 minute after hanging up I'm disconnected. I think to myself here that something is very odd here.
I decide to ring back and even if the internet comes back on fine I will explain the issue and hope they don't laugh in my face. Long story short after talking to someone I get a ticket number and am told they will optimise my line which will take 10 days to do and that I should leave my router on for 48 hours AND to expect a phone call within that time.
Fast forward to tonight and as I get home from work I decide that I am going to ring SKY and get this sorted as I can't wait 10 days just for some test to be carried out (As I don't believe it will fix the problem).
HERE is the strange part.
As I use the phone, the internet... comes back ON!!!! So, the internet only works (at the moment) when I am using my phone from the landline, very very odd to say the least! I try explaining this to SKY after being put through to a second person with my ticket ID and he says he has heard of this from 1 other person since he has worked there but he didn't understand it. Then the guy goes into various ways to try and find the problem from my end which I rule all out as I've already tried.. at that point, I'm cut off..... and then my internet cuts off.
Now I have rang a local number (free evenings and weekend package with BT) just to get online and post for some help here if possible.
I have tried looking at my router/network settings and changing one or two things I found online.
I have extracted the user/pass from my SKY router and used my old trusty router with the same result.
I have also tried using the main BT socket here which gave the same result.
I have formatted my PC (I formatted for other reasons not because of this) and I get the exact same issues as I did.
I have come to the conclusion that it is now out of my control and that I need SKY to do something.. but how do I go about this, I have never heard of such a strange problem and I would find it hard being on the receiving end of myself trying to explain this...
Sorry for the long post.
Have you got an ADSL filter on every socket? Have you tried different filters?
Have you tried the BT test socket. See here for instructions.
Are you using an extension lead?
Have you taken out the ringwire? See here for instructions.
