very odd win 7 64bit problem
29 May 2005
Bristol
if i enable the second hand on the "gadget clock "my cpu useage jumps to 50% and the gadget slows down to almost freezeing
although every thing else responds fine
its definatly useing 50%+ as my cpu temp gos up as well
any ideas?
ive tred uninstailing all resent software but no luck
im guessing a driver related problem but theres no new drivers on since this started happening
The gadgets on vista have always used ridiculaous amount of resource. Disable the side bar and try rainmeter.
it seems to be any of the animated ones, clock with 2nd hand , cpu meter etc
by the way this is on a duel core@ 4 gig
What Anti-virus product are you using? From what little I have found on Google some people's problem went away after removing AVG. Another possibility is UAC being turned off can cause high CPU usage.
i found the same with google :D
its not the problems mentioned as it was fine up untill yesterday im a bit stumped at the moment
btw thank you for taking the time to google it
nik
