Very Slow Boot and other problems
12 May 2011
Southampton
My trusty sig PC is having a few problems with booting (and i think related..ly) detecting my relatively new DVD drive. Motherbaord is a ASUS P7P55D EVO
I get occasional Blue Screens with error code which can be found here if it helps:
https://dl.dropboxusercontent.com/u/13203382/WER-24351-0.sysdata.xml
My POST sometimes takes about 1 minute, it hangs when detecting SATA devices. However, the POST is responsive, i.e. when I press Delete to enter setup, it immidiately says "entering setup...." at the top.
Always on these occasions, and also sometimes even when I have POSTed fine, my DVD drive is not present in Device Manager or My Computer. The little LED is flashing continually and won't eject as it thinks it is busy or something?
My HDD is also running sluggishly, with pictures appearing blurred for a second or so when I view them from my HDD and files and desktop icons etc start off as a blank white icon at first and then load up.
Help me OCUK- what is going on with my Motherboard!?
Can you post what it says in event logs for the time of the BSOD. The info in your dropbox is system info and nothing else.
The two errors (it BSOD and then hung at POST, then reset and hung at post but reached windows this second time) are:
Log Name: System
Source: Service Control Manager
Date: 14/07/2013 20:01:02
Event ID: 7026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Stew500R-PC
Description:
The following boot-start or system-start driver(s) failed to load:
cdrom
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
<EventID Qualifiers="49152">7026</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2013-07-14T19:01:02.193245100Z" />
<EventRecordID>12982</EventRecordID>
<Correlation />
<Execution ProcessID="532" ThreadID="536" />
<Channel>System</Channel>
<Computer>Stew500R-PC</Computer>
<Security />
</System>
<EventData>
<Data Name="param1">
cdrom</Data>
</EventData>
</Event>
the second one looks more serious?
A fatal hardware error has occurred.
Reported by component: Processor Core
Error Source: Machine Check Exception
Error Type: Internal parity error
Processor ID: 0
The details view of this entry contains further information.
+ System
- Provider
[ Name] Microsoft-Windows-WHEA-Logger
[ Guid] {C26C4F3C-3F66-4E99-8F8A-39405CFED220}
EventID 18
Version 0
Level 2
Task 0
Opcode 0
Keywords 0x8000000000000000
- TimeCreated
[ SystemTime] 2013-07-14T19:01:02.645645900Z
EventRecordID 12986
- Correlation
[ ActivityID] {8EC70E0C-4A32-402F-8ABC-67EEFF76B543}
- Execution
[ ProcessID] 1320
[ ThreadID] 1928
Channel System
Computer Stew500R-PC
- Security
[ UserID] S-1-5-19
- EventData
ErrorSource 3
ApicId 0
MCABank 2
MciStat 0xf200000000010005
MciAddr 0x0
MciMisc 0x0
ErrorType 12
TransactionType 256
Participation 256
RequestType 256
MemorIO 256
MemHierarchyLvl 256
Timeout 256
OperationType 256
Channel 256
Length 864
RawData
Hang on, I have a "Critical" from when the computer actually crashed, it was a few mins earlier. In chronological order:
"Event Log" The previous system shutdown at 19:56:58 on ‎14/‎07/‎2013 was unexpected.
and then:
"Bug Check" The computer has rebooted from a bugcheck. The bugcheck was: 0x00000124 (0x0000000000000000, 0xfffffa8007f8e028, 0x00000000f2000000, 0x0000000000010005). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 071413-13946-01.
and then:
"Kernal-Power"The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
WHEA-Logger / EventID 18 suggest issues with an OC. Can we load optimised defaults and test? Can you also test the memory with memtest?
