VGA hd cable xbox
22 Nov 2007
Im not receiving any sound through my tv speaker when i play xbox through the vga input. However when i put the tv on av mode in which the audio cables are plugged into the sound from the xbox works. Is there something i need to do to get it working through the vga setting?
it could be a setting on your tv in regards to the audio input? also your sure about which socket you've put your red/white or the 3.5mm jack from the xbox in?
is it an official cable or 3rd party ?
Hi
There should be a little single audio input socket marked (audio in - rgb/dvi this will give you sound via vga input but you may need to buy and adpater.
Google - 3.5mm Stereo Jack to 2 x RCA/Phono Female Adapter .
