When I first had my 360 I only had a 19'' tft to use it with so I did so happily with a VGA lead for a couple of months, I only had PGR3 and Kameo at that time and thought both games looked pretty fine but a little washed out
.... I recently managed to save enough for a sammy 26'' hdtv (same as 360 pods) and as everywhere I read said that component was the best connection I bought the leads and thats how I hooked it up.. As soon as I played PGR3 and Kameo on my new screen I noticed the colours were so much richer/deeper, seemed a little too dark for my liking but with a little fiddling overall it looked splendid. The thing thats
me though is that ive tried Oblivion and TRL and was not impressed much with the graphics, compared to the PC versions as both games seemed a little blurred and too dark, no definition, that was untill I reverted back to VGA. VGA with Tomb raider Legends has a MASSIVE improvement to visuals over component everything looks so much sharper and defined and actually looks better than the pc version which it definately did not when hooked up via component. Oblivion also benefits from VGA especially indoor/dungeon scenes, things can actually be seen much clearer which no amount of adjusting on composite can match. Its all left me a little confused as to which is the best connection to use,??Is it just me or anyone else notice this??
What display connections are you guys using/prefer??
me though is that ive tried Oblivion and TRL and was not impressed much with the graphics, compared to the PC versions as both games seemed a little blurred and too dark, no definition, that was untill I reverted back to VGA. VGA with Tomb raider Legends has a MASSIVE improvement to visuals over component everything looks so much sharper and defined and actually looks better than the pc version which it definately did not when hooked up via component. Oblivion also benefits from VGA especially indoor/dungeon scenes, things can actually be seen much clearer which no amount of adjusting on composite can match. Its all left me a little confused as to which is the best connection to use,??Is it just me or anyone else notice this??What display connections are you guys using/prefer??
