I'm a little mixed up with some converters that I am not sure would work with W7 64-bit OS.
I know that there's no chance of improvising the VHS "quality" to HD, that's not possible (upscaling, perhaps, but would not show any higher definition, that's for sure).
In short, I just want to buy a VHS-DVD usb convertor that would run nicely under W7 64-bit, and would convert VHS tapes to DVD (via the PC) in an acceptable quality where possible.
Any suggestions as to recommendations of any particular make/model? Would like to hear your views, especially if you have used it before?
Many thanks.
Many thanks.
