Vibration Dampening
8 Nov 2005
I'm just about to start putting together my new rig, and would like to know if there were any specific components that would benefit from a bit of dampening.
I'm using an Antec P150 case, and have already dampened the rear 120mm fan and the twin 92mm intake fans, but I've got a load of Silica Gel washers that I could use and wondered where I should be looking to use this, or even if I should be using them at all. They're just hanging around at the moment and I'd hate to waste them.
I'd guess that the optical drive mountings would benefit from a bit of dampening, but is a tiny little gel washer going to make any difference whatsoever, or is it likely to be all in the mind? Should I be whacking washers onto anything I can screw down, or avoiding them like the plague?
Id say, if youve got them use them. Certainly entertain using them on the hardrives, optical drives and fans, it even might be usefull using them on the psu. And anything else with moving parts for that matter.
I found it almost impossible to get my rubber washer mountings onto the side of my HD. There just wasn't enough space between the HD and the chasis....
Anyone got any tips? (sorry for the slight hijacking here :p )
I have used rubber fan mountings on all three of my fans :) They work a treat.
I'm using the Nexus Anti-vibration kit btw
If they wont fit, then they wont fit :p
Always the bungee method to silence the hard drives :) (See Sticky)
