- 7 Feb 2004
- North East
I used to use Dr Divx, but since i reinstalled after my latest build, it keeps giving errors
(ie the video crashes any media player i try)
I update to the latest DivX (6.4) and it came with the included converter (replacement to the Dr) and it does everything i need (BUT outputs to a .DIVX file
I am ripping DVDs with DVD decryptor, then encoding them to my MCE rig
I need sometihng that can :
Encode Vob1_1 , 1_2 etc into 1 video file (for DVD rips)
Ideally it will also encode a 2 part film into 1 single .avi too
Media must be playable on MCE (extra codecs etc no problem - so long as its a specific)
(ie the video crashes any media player i try)I update to the latest DivX (6.4) and it came with the included converter (replacement to the Dr) and it does everything i need (BUT outputs to a .DIVX file
)I am ripping DVDs with DVD decryptor, then encoding them to my MCE rig
