- 24 Apr 2011
I have a weird problem here. I go to watch YouTube videos. It has no sound
confused
and they stop working after 11 seconds (whilst using the headset. Ok, maybe my internet is bugged or my PC is playing up so I re start and try again. Same thing happens.
What confuses me is when I select the output device as the speakers, it works fine. If I am watching with speakers, then I swap over to the headset, then the sound stops from that point, and the video will get stuck 11 seconds after.
Now I know the headset is not broken. I used it on skype all night (and I believe videos were working yesterday night with headset) and I can hear sound from games/movies which I have on my PC.
I'm confused here. I googled, and basically what I go was just remove Hardware Acceleration & Update Drivers (which i both did) but it did not solve my problem.
Any ideas would be greatly appreciated.
confused
and they stop working after 11 seconds (whilst using the headset. Ok, maybe my internet is bugged or my PC is playing up so I re start and try again. Same thing happens.What confuses me is when I select the output device as the speakers, it works fine. If I am watching with speakers, then I swap over to the headset, then the sound stops from that point, and the video will get stuck 11 seconds after.
