Virgin media and Outlook express!
13 Dec 2005
ok I don't know if this is the correct place to post this but,
I have set up my virgin email address with outlook express and I can send emails with it but whenever I open outlook express it asks me for my username and password (which I put in) but when I press enter it just brings me back to the username and password screen and doesn't let me log on. If I click cancel I get the error code '0x800CCC90' and some drivel about my password! The password is 100% correct!
Any ideas?
Cheers
Check your account settings again.
The password may be correct but is the username for that mailbox correct?
make sure these are correct.
incoming = pop.ntlworld.com
Out Going = smtp.ntlworld.com
outgoing mail (SMTP) = 25
incoming mail (POP3) = 110
username is correct. The other things you sugested are also correct!
the password is correct.
I can send a mail from outlook express using this account and receive it in my hotmail account!
Check the account username and password settings again.
It is possible to SEND emails with the wrong details but not recieve them. Just altered my settings to confirm and this is the case. The error you see is because something is wrong with your account settings, most likely username and/or password.
ok guys thanks for all your help. I've now sorted it!
The problem was I was using one of my Blueyonder alias names as my username and after a little delving around found out it has to be the original username. Cheers folks!
lol
Right my next problem!
I'm setting up the virgin newsgroups in outlook express and followed the advice exactly. Whe I click on the "would you like to download a list of available newsgroups" I get this error
502 Permission Denied - Permission Denied -- http://www.highwinds-software.com/ (Tornado v1.0.6.380)
Configuration:
Account: news.virgin.net
Server: news.virgin.net
Protocol: NNTP
Port: 119
Secure(SSL): 0
Error Number: 502
Code: 800ccca0
Any ides?
Cheers
Right, sorted it. Bleedin' Virgin!
Apparently I have to tick 'my server requires me to log on'
Shame Virgin don't tell you this on their website!
anyway
cheers
