Virgin router - Netgear WGR614-6VGUKS Questions
Can't type for toffee
Don
14 Jun 2004
Newcastle U/T
I've not even plugged this in yet so no idea what firmware is on it.
the label states username as virgin and the SSID as virgin BB so Im guessin its a custom firmware.
Router in question is a Netgear WGR614-6VGUKS
Am in need of a switch and remembered I had this in the cupboard.
Plan is: Disable DHCP, set static IP, connect to other router and use it as a switch.
Question is:
Should I even bother trying this if its Virgin firmware?
Or am I better off flashing to a different firmware first?
Well Virgin tend not to have the Netgear routers flashed with their own firmware. It just tends to have virgin as the username.
Although my Netgear is a DG834G, It was given to me from a friend who had Virgin and I can use it on BT's service just the same and there is nothing different than a retail version.
