Hi all,
I have an issue using my secondary Superhub 2 as an access point.
Essentially I had a couple spare and thought I would just use them to extend my WiFi.
With that in mind, I hooked it up to my PC, reset to factory settings and set the following config:
Once they network was back up, I was able to use the secondary router to plug my PC, NAS etc in and the WiFi also worked just fine. IE When I went into my office (where the secondary router sits) the Wifi on my phone switched over and all was good.
However, after some time (sometimes a day), the WiFi on the seconday router jsut stopps working, it no longer seems to be broadcasted and my phone wont connect or find it.
The wired deviced still work fine tho.
I thought I messed something up so I set it up again from scratch and the same behavior was observed, ie working initially but then just stopps.
I also got hold of another Superhub 2 which I set up in the same way, thinking maybe the hardware is broken but if does exactly the same thing.
Has anyone got any advice on what the issue could be?
I know I should probably get a proper router but I am not that fussed too get super high speeds, the superhub would work just fine for me and I have 2 of them lying around.
Thanks in advance
- Same SSID as main routers wifi
- Same password
- Disabled DSCP and Firewall
- Set a Static IP 192.168.0.2
- Main Router is 192.168.0.1 (and set to assign IPs from 193.168.0.3-254)
Thanks in advance
Fingers crossed
