Virtual Mac?
Status
Not open for further replies.
5 Mar 2007
Macclesfield
Hello,
I may have to use a Mac soon and as I have no experience whatsoever I'd therefore like to have a little play. I've got the PC in my sig. and I've got VM running another Win 10 machine. Question is, is it possible to run Apples software on a PC?
Yep.
You'll need to get the installer off a real Mac (Or... ahem... sail the seven seas...) but apart from that it works in all major virtualisation suites.
It can be done and pretty easily. Do a wee Google and confirm what you need to do with the virtualisation app you're using to make it work.
According to the licence, you can only virtualise Mac OS on Apple hardware so what you are requesting is against the licence and can't be discussed here.
Status
