- 26 Feb 2007
- Germany
Hi Chaps, just joined the forum and have the following scenario before installing windows onto an upgraded PC:
My current PC is currently running windows Vista Ultimate 32-bit. Which seems to work fine with all my apps’ System spec is:
P4 3.2 800FSB
Asrock P4V88 Mobo
2GB DDR400
ATI 9800 Pro 128MB AGP
80GB IDE system drive
200GB SATA Raid 1 (Mirrored) data drives.
I’m waiting for some new parts to arrive so I can completely rebuild my PC some of the parts are as follows: (Ordered from OCuk of course)
Intel core 2 Duo E6600
Asus P5N32-E Plus SLi Mobo
Corsair 2GB DDR2 XMS2 PC-6400C4
BFG Geforce 8800 GTS 320MB PCI-Ex
Enermax Galaxy 1000W PSU
2 x 500GB SATAII Barracuda drives for Raid 1 Data Drive (Mirrored)
250GB SATAII Barracuda system drive
with existing Aopen and LG DVD-RW DL drives and Thermaltake Xaser III Case.
My quandary is this; considering the following applications that I plan to run on the new system should I install the 64-bit version or stick with the known 32-bit version.
Norton Internet Security 2007
Adobe Acrobat Pro 8
Macromedia 8
Nero 7 Ultimate 7.5.9.0
PhotoShop CS2
DivX 6.5.1
Daemon Tools 4.08
DVD Shrink 3.2
Nokia PC Suite 6.82
WinZip 11
Xara Webstyle 4
Office 2007
My plan is to dual boot with XP for games until better drivers and DirectX10 is sorted so only interested in application support under 64-Bit environment.
If anyone has had experience on the above mentioned App’s then advice and guidance will be appreciated.
P4 3.2 800FSB
Asrock P4V88 Mobo
2GB DDR400
Adobe Acrobat Pro 8
Macromedia 8
PhotoShop CS2
DivX 6.5.1
Daemon Tools 4.08
DVD Shrink 3.2
Nokia PC Suite 6.82
WinZip 11
Xara Webstyle 4
Office 2007
