Vista 32bit or 64bit?
15 Nov 2003
Marlow
Why on a modern/new system would you not choose Vista 64bit?
I assume at least it runs a bit faster?
The only real use of the 32bit platform would be certain hardware/software or peripherals that would only work on the 32bit platform.
Oh... What's the point of it then?
Primarily that you get to use more memory.
What is the point of 32-bit over 64-bit is the question and the answer for most building modern rigs, is nothing.
From an article I read, Vista 32bit loads up in nearly have the time of 64bit :eek:
It can, and does on HL2, other Source titles are being 64bit enabled in due course.
