Could try uninstalling everything you have and installing:
Vista Codec Package - this should let WMP play almost anything.
VistaCodecs x64 Components - this should let WMC play quite a few things (though not as much!).
I use k-lite on Vista 64 and have never had a single problem.
If you are using x64 vista, just change it to make Media Centre 64bit the default, its really easy to do
Kimbie
What rubbish, it is x64. You are thinking of Media player.
